71RALLYEDART
Aer a slant 6 and v8 kframe the sameme and just the motor mounts are different?
The basic frame is the same but the metal stands made on them are different. You will have the biscutt type, 1972 back and the spool type, 1973 up.
The basic frame is the same but the metal stands made on them are different in each of the following.
There is a /6 and a V8 You will have the biscutt type, 1972 back to 1968 and the spool type, 1973 up.
1967 is all by itself and has two diffent engine mounts also.
