Louis,
Impressive build you have going here. I've been lurking for a while. I was really close to buying this car myself, but I'm glad you scooped it up.
I noticed you ran the vent line up into the trunk area, put a few loops in, and ran it out to the fill neck area. I was wondering if you had any provisions for a one-way valve in this system? I had to create a fairly custom vent on my fuel system and I figured I had to run a one-way valve that would only let air in so that fuel would not leak out in the event of a roll-over.
I'm not sure if the coiled fuel line will prevent leaks in a roll-over, but I'm also not sure if a check-valve is required by tech.
Just thought I'd mention it.
Take care, and I look forward to seeing more updates!
-Mike
