johnmucci
moparmucci
I bought a 65 dart 273 4 speed last night.....the driveshaft had to be installed as it was towed using a tow dolly.....questions:
1. does the 4 speed have fluids like an auto and if so where do you ck it?
2. Even if you push the clutch to the floor, when stopped its grinding a bit going from reverse , 1st, etc.??? could that be fluid related or maybe clutch adjustment??
