Hey, guys! Next project is to refresh the stock front disk brakes on my 'Sport.
I'm desperately hoping that the original calipers can be saved...what are the odds?
Sitting on the bench, I have fresh rotors, pads, flexible lines (the ones on the car are almost certainly the originals...look scary)...what else should I replace while I'm at it?
When everything is apart, is it typically a good idea to repack the wheel bearings? Do I need to worry about "lip seals"? If the master cylinder isn't leaking, can I assume that it's ok?
What kind of fluid do you guys suggest?
I have a very generic Valiant/Dart shop manual that isn't helping much so any tips or experiences would be appreciated!!
-Mike
-Mike
