T67POWER
- Joined
- Sep 30, 2009
- Messages
- 669
- Reaction score
- 9
Well i went to the track again tonight to try and get some tuning done on the 67 cuda and enjoy some bracket racing also.
I took off my 7 blade stock fan and installed my clutch fan --knowing full well -- the motor would be running a little bit hotter.:angryfir:
All in the search for a quicker ET.
SO......................
1.)My first run was 14.158 @ 95.54 == a tenth better then the last time at the track even though my 60 foot short time was 2.004.
Last time it was in the 1.94/1.95 area.
It's very slippery on street night.
2.)Next run was my first elimination run ---14.15 dial in
car ran 14.370 @ 84.37 -------I let off the gas and then got back on at the finish line.
>>>>>I cut a .010 light and was way out on the guy.:cheers: I win.
3.)This next run had a very strange outcome........I dialed a 14.21 because the track was getting slippery and traction was bad.(2.111 60 foot)
I ran a 14.379 again---- BUT..... at 94.27 --on the brakes at the line.
I got a .027 light BUT--- he cut the tree down to a .006.(I lost......:sad5
TIME FOR TIME TRIALS.
The faster this 318 gets, the hotter it gets, and in bracket racing that's just not a good situation to have happen.
4.)I get in time trials and decide to lean the primary's out one size to a 70 jet from a 71 jet ---------81 in rear.
The car goes 14.23@95.27.
I run the car two more times to see what works the best shift points.
1.)I try o lower shift point then 6000/6000 and shift the car at 6000/5500 -------------------------------it goes 14.30@94.26
2.)I run the car again and shift at 6200/6200.
------------------------------ The car goes14.18@96.11.
NO WONDER THIS 318 FELT SO GOOD WITH 4.56 GEARS.
225@50 cam.......453 lift 108 lsa. PAW CAM/MADE BY CRANE
I can't wait to see what this car will run with.....
A.)a real radiator
B.)26 Inch slicks and or re-install the 4.56 gears with the spool.
Who ever said a short cam won't rev past 6000 grand and make power.
Next time out i might do 6400/6200...............lol. 318'S.....:burnout:
A.)a real radiator
