us car tools rear spring relacation kit
That looks like an excellent kit. It allows use of the factory bolt holes to help you locate everything in the proper position.
Agreed. Looks like location of the mod is guaranteed. For a person like me who is not much of a fabricator this would be a great advantage. Using the facotry holes creates height, depth and side to side alignment.
i downloaded the installation instructions not much to go on how would you go about checking the car for square,making sure the rear end is where it should be,What would you do first frame connectors then relocation kit.I am putting left front floor pan in also left side inner and outer rocker panel i figured frame connectors first then weld in brace supports before removing floor and rockers install inner and outer rockers then floor then finally install relocation kit.Does this sound like the right order?thanks [ame]http://uscartool.com/wp-content/uploads/2013/05/Spring-ReLocation-Kit-Instructions.pdf[/ame]
