I just replaced the clutch pressure plate and throw out bearing on my 67 cuda 318.
The pedal feels good but when pushed it stays on floor and won't spring back.
double checked the throw out bearing install springs placed same spot all is the same as it was but the threaded rod is all the way to the end and still wont pop off floor any ideas.
