If someone here could explain to me how to set the lash in my 3rd member I would appreciate it. It is a 489 case with a posi. I've read the the "manual" but it's like reading german to me. Talk to me like I'm 10 yrs old. lol.
running used gears. replacing bearings on the posi.ok are you running new gears or used ones?
Tighten cap bolts by hand then screw in adjuster to take out all lash in the gear. Torque one bolt on each cap and set backlash to 1/2-1 1/2 thou (basically none).
Now this is the part I didn't understand at first, your tightening only the one adjuster to "push" the ring away from the pinion to get backlash and tighten (preload) the side bearings in one operation. Torque the other two bolts and recheck backlash.
There is a bit more to it which the manual states ie rotating and checking in 4 spots etc..
sorry. in the words of the GREAT JOE DIRT...."Posi-trac"Posi. So you're runnin a chevy rear end.
I think I can get my hands on a magnetic dial indicator. So you're saying tighten one adjuster to push the ring gear to zero lash on the pinion. Then tighten the other to push ring gear away .006-.010 from the pinion, while not moving the the first adjuster at all. correct?This is the way I've set them for 40 years and is the way Yukon Gear explains to do. Take almost all the play out of the ring and pinion. Then tighten the side that pushes the ring gear away form the pinion to get a backlash of .006-.010.
You need to have dial indicator and a magnetic base to set backlash.
I did not take that measurement before disassembly. I did mark the caps. Also I took the suregrip and ring gear out without moving the adjuster that pushes the ring into the pinion. This is what the guy I bought it from told me to do.you took a backlash spec measurement before pulling it apart right?
I'm sure it will howl. by the looks of the grooves in the pinion, it wasn't set up right in the first place.Keep in mind once you have it back together you might encounter some howl from the gears.
I've never took before measurements. whats the point, its all coming apart and will be setup once its all together. maybe someone explain this reason ??
