in car cam
85glht
CT.
Took a video last week when I was at Lebanon Valley. Enjoy
[ame="http://www.flickr.com/photos/17366205@N02/10098641906/"]20130928_114702 | Flickr - Photo Sharing![/ame]
Yes, I know I red lit :(
What's it run? Sounds really mellow, much like mine. Good job on shifting
Thanks!!
That pass was a 12.4 @ 113.5. It has a small camshaft .540 ish lift. Was hoping for a little more power after the head porting from last summer. The car showed 35 more hp on the dyno this spring but didn't show any improvement on the track.
Car NEEDS slicks too. Using drag radials now. It spun out of the hole every pass. One pass, it wheel hopped really bad, had to short shift into second.
Thanks!!
You can sure lose a lot of time spinning. Your MPH vs. time reflects that. Maybe if you get it hooking you'll see that improvement you were hoping for.
You ain't lying! Gonna look into some slicks for next season.
