That's correct although both are 66 and up manifolds. Look at the bolt holes. I'd say the top manifold is a 68-69 part. Ports are the same on both. Larger ports were found on the LD340
I just measured both intakes. The ports on these are roughly the same size. 1.05-06 wide and 1.93-94 high. The bottom manifold has had the intake bolt holes enlarged so I can not tell what size they were originally. The top manifold looks un-touched.
Just for grins I measured my D64 and those ports measure 1.51 wide and 2.03-06 wide.
Edlebrock appeared to have changed the carburetor flange area to a rectangular casting in order to leave enough metal to allow machining the primary and secondary ports to larger bore sizes. It looks like the earlier design only left enough metal for opening up the secondary ports for a spread bore carb.
