Ronnie Sox Tests the 'new' 383 Road Runner
Road Runner 'Coupe'
383/335 HP
4-Speed
3.55 Gears 'Sure-Grip'
E-70 x 14" Tires
Shipping Weight.... #3422 lbs.
Curb Weight......... #3540 lbs.
In 'stock trim', right off the factory production line, Ronnie hit several 14.70's @ 95 MPH.
With the Air-Cleaner removed, and 'Chrysler Tech' Mark Pearce making adjustments
to the 'timing, carburetor and clutch'
Best Result....................14.46 @ 97.1 MPH
Ronnie Sox,
'The Road Runner is surprisingly light for a mid-sized car {B-Body},
and for $3000, you can't beat its 'Performance vs. Sticker Price'.
'I would have liked to test it with 3.91 or 4.10 Gears and some better rubber.
And maybe add a 'Dual-Point' Distributor and a bigger Carburetor {Carter 750 AVS}
off of the 440 Super Commando. We'd easily break into the high 13.00's.
