plumkrazee70
Will a 73 dart dash bolt up in a 70? Also I know the 70 instrument cluster is horizontal, but will it bolt in place of the 73?
Thanks.
Thanks.
If you replace the entire dash assembly it will bolt right in.
The problem will be getting the dash frame OUT. Originally, the bolts were installed at the factory before the windshield was installed. "I've read" on here that a couple of guys got these apart without pulling the windshield, but I don't know HOW.
I'm planning to pull my bolts with the windshield out (car getting painted) and reversing the clips, shorten the bolts, and put them back in from below, so IF I pull the dash later, I can do so.
My windshield is cracked and needs replace anyhow. Will the instrument cluster from the 70 bolt into the 73 dash?
Sweet. Will the 70 horizontal cluster bolt in place of the 73?
you will have to hack the crap out of the dash
See Here: http://www.forabodiesonly.com/mopar/showpost.php?p=1969905973&postcount=18
No. Just use the shape of the speedometer as a guide.
If that instrument is different the instrument housing is different and the opening for the housing in the dash for it is different.
If you are going to pull the glass there are lots of 70 dash frames around because they came in every 70-71 (72?) dart and usually the swap is to take that standard dash frame out while switching to a rally cluster. If you switch the frame and it's a street car remember to swap the VIN plate on the dash frame to your original or you could run into problems with registration and insurance
