11 3/4 rotor sources, price and quality
CichliDart
Well, where is it now?
SF East Bay, Antioch CA.
If you have a source for quality inexpensive Rotors for the 11 3/4 rotor upgrade please share.
I Bought the Dr. Diff Upgrade kit, brakes, pads, bearings, master cylinder etc. I have the Spindles with the adapters I just find myself hesitating on pulling the trigger on buying them.
I assume the drilled slotted rotors are worth it for cooling.
Any advice is welcome!
Thanks
Mike
Check out Rock Auto. 1979 Chrysler Cordoba Premium Power Stop drilled rotors 11.75 dia at $80.00 ea is a steal. They eat half the freight cost also. Check it out we have used several of these on large brake conversions. Just check run out with a dial indicator after you spindle mount them as you would with any rotor. You really don't need the drilled unless your going to road race.
I put the powerstop drilled and slotted on my Titan and my wifes escape they are amazing so far. All winter driving in the salt and there isn't a spec of rust on them and my truck stops far better then the stock rotor and pads.
I bought some Bendix brand ones from summit. PRT1132. IIRC those were the best deal I could find when the shipping cost was included. So far so good.
Check out theramman.com. Or YouTube ramman. The 22 min video on Mopar breaks will tell you a lot.
I bought my drilled and slotted rotors from dr diff 11 3/4 i think 180.00 shipped
