Gear's
Eddy carbs are good for cruisers, but if you are looking for the most POWER get a Holley style carb (Holley, Demon, Quick Fuel, etc). 750 would be fine for your 360 (and would be even better with a HP or Proform main body).
3:55 gears are a great all around ratio. You can have your cake and eat it too with them.
yep! mopar or no car! moparfest at greatlakes dragway is what i look forward to all year.
I found some tow hooks in the garage from the jeep. We should weld them on your k-member.
I think i'm going back to 3.23 gears cause it just sucks the gas with 3.91
It's going to suck gas no matter what it's a 410 ci motor! what you thought you were going to get 40+ mpg!it really won't help when your doing burnout's all the time.
