Thanks for the photos. I posted photos of my 65 column rebuild a few years ago. I keep telling people back in GA there are hillbillies in CA. The prior gomer owner of your car proves that with the broken coupler fix, and apologies if it was a relative.
You can get a rebuild kit for your steering coupler for $15 on ebay, though yours looks fine. $10.50 for the turn signal cam is great and about what they cost when they were in the Help bubble packs at stores. People ask >$20 for the SM9 one for early A's. I think the later one works, if you just don't use the wire.
nor do I have to deal with potentially shady sellers. I never used my eBay account (though I've had it for about 5 years) which will make it hard for people to deal with me.
Can you point me to your thread on rebuild of the 65 steering column and how to replace the turn signal cam. I've got broken ears on my plastic cam but I dont' see how to remove it from the body of the signal switch without tearing things up. It has that metal collar that holds it, Is it possible pry apart and replace?Thanks for the photos. I posted photos of my 65 column rebuild a few years ago. I keep telling people back in GA there are hillbillies in CA. The prior gomer owner of your car proves that with the broken coupler fix, and apologies if it was a relative.
