rymanrph
I've never had any before and the ones I have now are too pressurized so the rear end of my car is jacked way up. Everything I've read just talked about using what you'd use with a tire valve, but the connections on my shocks are bigger than that.
I'm sure there is a simple solution, but having never messed with them I'm a little unsure.
