carb size for 512 stroker?
Carburator is the last part of the equation. Cheapest way to get it to run like a rapped ape is to change out the cam and max out the potential of the head flow he already has on tap.
That change alone will be like going to bed with a sex crazed Nympho Chick. You better be holding on tight and ready for a ride!
