slantsixdan
Here's one nice fuel pump. Genuine Chrysler part number 2525 679, note "DPCD" logo on the air dome. Really nice castings and bolt-together (rebuildable) construction; rebuild kits are easy to buy and install. Inlet and outlet valves and diaphragm tested; all seal perfectly. Pump body is threaded to accept whatever straight or angled brass nipples you prefer for a tidy installation in your application (such as if you're doing the fuel line mod). Made in Canada, not in China. Unlike the junk available in today's parts stores, this pump has the arm damper spring so it won't knock and rattle for you. I had two of these; the other one went on my '73 Dartit worked without fault for four years of oxygenated/alcoholic gasoline, and last I heard from the car's new owner it's still working without fault.
$44. Shipping from Seattle, WA (or Vancouver BC for a Canadian buyer).
