[FOR SALE] Lots of parts! little of everything Mopar!
zac_F71
Clitherall MN 56524
All prices are OR BEST OFFER - and do not include shipping unless noted (will not ship motor/trans)
71 225 slant 6 engine many new parts runs great comes with lots of parts $200 90k miles
- will take $200 for engine/trans
71 slant 6 A904 has new filter installed same miles as the engine works great $100
Scarebird 10" disc brakes setup on A body 9" drums - setup with 1 off hubs for BBP (5x4.5") $400 shipped - have $700 in it
A, B, and E body Monroe Blue shock set (all 4) brand new were mounted but never driven on $75 for all 4 shipped
A body 2.5" slant 6 leaf springs w/ new rear shackles (OEM) $50
2.5" axle tube shock plates and new U bolts will separate $50 for both shipped
A body stock upper A arms w/ new small ball joints $40 need bushings - 1 joint is welded in
A body stock lower arms (missing torsion bar tensioner) $40
A body stock struts rods $25
A body 7 1/4" rear end - open dif 2.76 ratio from 73 Dart Sport BBP no brakes ready to use $100
stock 8 3/4 pinion snubber $25 shipped
SBM A727 trans out of running 340 car $150 - it's a slush box but works
79 360 block and crank bored .030" cleaned and painted $100 new frost plugs as well but crank needs turning
383BBM small valve heads $40 for both
Scarebird brakes
Are you parting a car? What's wrong with the 727?
Sort of parting yes - I bought a new front end including brakes and am just moving forward with the project (and trying to recoup a little money from the $2,000 front end)
Nothing is wrong with the small block 727 except there is no converter- we drove our numbers matching 70 340 Dart to SharaDon's to have them rebuild and install the numbers matching 727 - we bought and drove the car with this trans for a few months
it's a good trans for a driver or someone looking to get a car going..
I am interested in the Scarebird brakes. Lets figure something out. Thanks. John. ( I have a US address for shipping. Makes it easier for US sellers so they don't have to mess with custom forms)
