Hellwig: Early A front sway bar question - Dave?
swing69
fightin' socialism
Central Socialist NJ
I'm using a Hellwig 55914 bar. I'm waiting for Dave to chime in to clarify;
1) will the Hellwig bar work with stock OEM tabs on a 65. IF so....no interference with the LCA strut? I recall the stock bar (smaller diameter) is pretty close to the strut.....
2) should I just use the upper position? (L bracket at the shock bolt)
I'm ok either way.......
THANKS!
Glad you found the correct answer 'cause Dave's not here man...
Later, David...
