IRISH RT
Anyone ever done this with an Edelbrock and got good results ?????
I suppose you're talking about leaning one out? I've done it a few times with Holley's, but in general, anything more then a "step" leaned them too far. If we're on the same page, we are talking about the primary side here? The factory setup on most street carbs is about as lean as they like to run, from what I've seen.
If you're trying to lean a "big" carb to run on a mild combo, while worthy of trying, I'd look to step down to a smaller unit at some point.
eddy carbs have larger primary jets than the secondary cause they have metering rods occupying space inside the primary jets...
Yes But On The Street You Not out of the Primaries Very Often unless your over half throttle or WOT, So Why do the Primaries Have To be Rich , Its The Secondaries that Matter At Full Noise ,
The smaller Eddy carbs are the opposite. Up to 600 cfm I believe the primaries are smaller than the secondaries.eddy carbs have larger primary jets than the secondary cause they have metering rods occupying space inside the primary jets...
I was talking about jetting, not physical size. Sorry for not wording that correctly.They are physically the same size (will interchange) on my 600, but smaller ID by a few steps in the secondaries out of the box .
The jet/orfice size should be for the correct A/F ranges throughout the RPM band. If that means it's done while upside down in a trash can to get right, so be it.
At full thottle, provided same size throttle bores, you would like as close to a 50/50 distribution from primary and secondary bores. Putting smaller jets up front with a rod stuck in it may cause distribution to become unbalanced. Having the front feed 40% or less and the rear 60% or more will not be a good set up and cause rich back cylinders, lean front, even though it all drop into the same mixing hole and be a 100% number.
As Tony stated:
The metering rod is the reason the primary jet is larger. If someone told you that was wrong, you need to do some math to calculate surface area of the opening. The amount/area a rod takes away from the opening is a big factor in why you usually have a larger jet up front. The rod is down in the jet all the time, even at WOT. That's how it meters for LESS fuel when you aren't on it.
Grab a book on how carter or AVS style carbs work, it will help explain the design/methodology.
And that is why I run .098 all around but plan to drop the secondaries down a size or two. (the needles in the primaries)
I run about 14 to 1 or so in all ranges exept my WOT is a bit fat, so .094 in the secondaries should get it pretty close to good A/F ratio as well as a decent balance. (square bore carb)
Can you use a carter strip kit on edelbrock carbs
So what engine are you running 98s on , I need a mininium of 104 on a worked 360, its so hard to read plugs these days with all the additives in current fuels, so trying to tune by the seat of my pants my first jet combo yielded more more power through the range ,have done a couple of thousand miles on the street with my first combo , just dont know if its a little lean for the 1/4,
Can you use a carter strip kit on edelbrock carbs???
