If you've swapped a 66 or later transmission into your 65 or early early A, then the original speedometer cable won't work. Your need a 66/67 cable to mater with the later transmission speedometer pinion adapter and the early A speedometer. I've got 2 here; I was using the black one in my 65 Dart and the one with white paint on it came out of a 66 Barracuda (still has the firewall grommet attached. Got my wife to hold it so both ends could be seen. $20 plus shipping from 22657 - your choice.
