[SOLD] 8 3/4 axles from truck/van/ or C-body to use for narrowed A-body project
pitbill
Bluefield, WV
Looking for axle shafts from 8 3/4 out of a truck, van, or C-body that I can cut and respline for a narrowed A-body Dart project. If you have anything sitting around let me know.
Will be going a different direction and having new axles made for my 8.25 rear project. Thanks to all who replied.
I have 8 3/4 axles and 8 3/4 ends I could sell you. Let me dig them out of the garage and take pics.
..............I always want to avoid resplined axles as I've had a couple break and a couple twist.........when they break it usually costs a tranny/.............kim.........
if you do this make sure there is enough "beef" at the end of the axle to be re-splined. not all of the axles you listed are the same. some taper down at the end. Its a hit and miss deal trying to find the correct ones
Will be going a different direction with my 8.25 project and will be having new axles made instead of resplining 8 3/4's. Thanks to all who replied and for the advice.
