MRL Performance
This is one of my most popular builds with a cam I came up with a few years ago. And after some testing and dynoing I have new chamber mods that are going to take my builds to the next level. I would love to show you, but I would love to keep them in house.
This is a 340 build that will knock your socks off and Im super happy with the way it came out.
340 block prepped and ready for build 4.100" bore
SCAT 4.00 crank
PEP I beam rods
Diamond dish pistons
TS rings
MRL custom HR cam 239-243 .550/.560
Procomp head built in house, Stage 2 porting w/chamber mods
Comp roller rockers
RPM AG
EZ EFI 2.0, THE BEST EFI SYSTEM OUT THERE
Anti friction coatings and thermal coatings
All the rest of the little things to make it complete
Torque. Its something we all need. And its like a good drug, its very addictive. Once you have a taste fro it you want more and more. And this SMALL block with a fairly mild cam has a lot, and then some.
How does 500+TQ at 3100rpm sound? Pretty damn good right? Well how about if I told you it held 500+TQ all the way to peak HP at 5700RPM? Holly CRAP! Peak you ask? An Astounding 562TQ at 4350rpm!!!!!
Top end didn't suffer either as it made 547HP at 5700rpm.
All pulls were made at or above 180*, and 32* total timing. With only 18* timing at idle it was pulling 13in vacuum at 850-900rpm. If we bumped the timing up to 30 at idle it pulled 15-16in vacuum(simulating a vacuum advance setup).
SCAT 4.00 crank
PEP I beam rods
TS rings
Comp roller rockers
RPM AG
