[FOR SALE] Parting '63 Valiant convertible
RJG
Oceanside, CA
I am still parting out my 1963 valiant vert. No power steeing, no disk brakes. It is a /6 with 3sped auto, column shift. Headlight trim rings were sold.
Let me know what you need and I will send pictures.
Is the wiring harness good ? Maybe the dash cluster also? I'm in the process of buying one with some electrical issues.thanks
The harness is OK. A couple typical splices for radio, etc., but it worked well in the car. Do you need just the gages, or do you also want the bezel. I have both, in clean condition. I can get pictures to you in a day or so. Some long hours this week, need time to pull them off the shelf.
Richard
I need the wiring harness for sure ... both of them .The under the dash and the under the hood.let me know how much for the harnesses and the whole cluster.I might also be interested in the passenger side front fender.Sorry I took so long to reply...been busy at work too.pm me if you want.
do you have the stainless trim for the rear wheel wells? Not sure what models came with it.
Unfortunately my car did not have that wheel trim. Sorry I couldn't help you.
rjg
Hi, I'm looking for one (..or two) decent hydraulics for the roof. Also the snap-on cover that goes over the top when it's down (boot cover?).
Tom.
I need ALL the screws and springs from the headlight buckets. I have a 65 cuda and the front fenders should be the same ???
