1GTMOPAR
65 DART GT CONV
Clutch fan with aluminium bladed fan. Like new 100.00 plus the ride
Early A stock exhaust manifolds with downpipes for true dual exhaust 150.00 plus the ride
New Mopar flex plate never used 60.00 plus the ride
Floor shifter with linkage. Missing knob with button but fully functional 50.00 plus ride
Mechanical fuel pump SBM used once for about 50 miles before swapped for electric pump. 20.00 plus the ride
65 Dart horns. 10.00 each plus the ride
Early A factory jack with foot plate 40.00 plus ride, additional plate 5.00 plus ride, hols down 5.00 plus ride, Jack mechanism without post 10.00
Harmonic balancer off of my 340 with center bolt. will work on 318 as well. Rubber in excellent condition. 20.00 plus ride
O.E 4 speed clutch fork boot. Not ripped in excellent condition 10.00 plus ride
Small block oil pump drive. In good condition can be used in engine or modified for pre oiler 15.00 plus ride
O.E styl ignition coil Part# 29910. used once in great working order, tiny dent in bottom but in excellent shape 20.00 plus ride
Factory Hurst 4 speed shifter from my 65 Dart Gt. Hurst competition plus in great working order 120.00 plus ride
Early A pittman arm 10.00 plusride
8.75 pinion snubber O.E 15.00 plus ride
Tranny Dipstick tube from early A 904 10.00 plus ride
8.75 rear Axle retainer plates 10.00 plus ride
Small Block fully self contained distributor. Used once then switched to MSD. worked great no need for external ECU quick hookup 30.00 plus ride
O.E electronic distributor works great no slop in bearing 15.00
New 10" rear drums big bolt pattern. Bought these several years back before going to disc. Minor surface rust, brake surface not pitted just surface rust 40.00 for the pair plus freight
Edelbrock 318/360 Performer aluminium intake manifold. Was on a little 318 I had and worked excellent. Much like the LD4B manifold. 100.00 plus the ride. will pair up with rebuilt edelbrock 600 carb for package deal at 180.00 plus the ride
Factory Cast Iron Commando 4 barrel intake manifold. 2465726 Never molested or drilled to fit non 273 engines. could use a quick blast and paint and would be real nice. 100 plus the ride.
I also have fender trim for 65 Dart Gt convertible for top of doors,fenders and rear quarters. if interested PM me for details. I have some other 65 Dart headlight buckets etc that I may be willing to part with. Some prices negotiable
