Well I put the duster off to side for a few months. Initially I was just going to leave my truck N/A but I've been wanting to build my first turbo setup. Building everything myself. I'm hoping for 9s So here it is. Tell what ya think
motor-
74 360 .030 over half fill
icon 9.2 pistons, scat h beam rods
CAST crank lol with studs
ported 308 iron heads big valves
custom solid cam
850cfm blow through carb
Trans-
A518
billet input and servos
full manual valve body
2800 stall lockup converter
upgraded clutch packs
turbo-
Out of the box s475
1.32 AR t6
Percision 46mm waste gate
tial 50mm bov
big air2air intercooler
Rear end-
Dana 60
spool 3.54 gears
Moser axles
motor-
custom solid cam
Trans-
A518
turbo-
Out of the box s475
1.32 AR t6
tial 50mm bov
Rear end-
Dana 60
spool 3.54 gears
Moser axles
