Anyone with a 73-76 Hellwig front sway bar.
71valiant
Make fast, break, repeat.
Columbus, Indiana
Would you mind taking a few pics and posting. I'm really needing specifics on the control arm brackets. Exactly where I'm needing to drill for them. Very much appreciate it.
As I understand it, there's no drilling necessary on their front sway bars. The brackets that support the bar are bolted into existing holes on the K member.
The 73-76 require drilling. I'm just needing a pic of the control arm where they have it drilled. Just to make sure I place it right. I have the directions, but its a close up of the area.
Yes the 73-76 LCA's have to be drilled for the LCA mounts if they don't have them from the factory.
I have that bar, but I don't think my car will be any help, my LCA's have the factory brackets.
I have a picture on page 2 of my build thread that shows where I mounted mine. I chose to weld instead of drilling because why not.
Hope it helps.
On the instructions, its showing to drill low on the arm, but everywhere else I see, its up higher.
