LS power steering pumps for low pressure
mcat
cincinnati ohio 45251
All the post i found in a search are dated.... i am looking at stock stuff, not high dollar afyer market options.
what is out there with the reservoir attached, that will install easiest? For rack and pinion?
I used an ls1 pump. Bought a bracket from RMS. I bought a Dorman pulley that's the same as the hemi and used a stock size belt.
Riddler
I used an ls1 pump. Bought a bracket from RMS. I bought a Dorman pulley that's the same as the hemi and used a stock size belt. Riddler
Exactly what I did, and it works well with my power rack and hydroboost setup.
Should be using a Ford ( low pressure ) pump with a power rack ( most are mustang 2 ). Speedway motors sells a nice GM style, but low pressure pump.
