[FOR SALE] 1965 Barracuda Parts Car
cosgig
MoBro Inc.
Pinckney, Michigan
Howdy all, cosgig here! I'm currently parting out a 1965 Barracuda parts car, and although everything will be up for sale except a couple items, my question here is about the motor! It's a /6 auto, and although it turns over with the key, it won't fire up! I don't want to spend much time on getting it running, so my question would be whether to even save it or not! I believe it's a later motor but don't know where to look for any identifying marks! What say people, should it stay or should it go! I only need the windshield, and it has a V8 center link in it which is spoken for, other than that, it's all up for grabs, including the entire car! No title, just a parts car!!!
Looks like at least a 1970 engine. I'd take it if you were closer.
I'd like the whole car if it was restore-able and had paper work
While anything is restorable, this car was in a building that collapsed on top of it, then they pulled it out of the building by the nose! The roof is crushed in, the front end, including the fenders are bent all out of shape, every panel has rust through issues, the passenger floor has already been patched...badly!! And, no title!!!
the slant ?non runner. most people just give them away to get rid of.
if you had space to store it, IF you ever thought there would be a need for it. around here one that would run good, might bring $100,,,, MAYBE!!!
Geof, I need the hardware of the headlight buckets. Springs , screws all the parts to adjust and hold the headlight in the car. I don't need the chrome stainless rings, just hardware.
Thanks
cosgig, Have you seen any Formula S power brake boosters. Bought one from aftermarket, and it was HUGE, if I can't find a smaller one the fits, I will be forced to run manual brakes !!!!
