1972_Demon
Demonic Member
I got to the track last night after changing from a carb to multi-port fuel injection.
Also did the spring relocation, caltracs, and 325-50-15 M&H drag radials.
It's a 360 with unported J-heads.
Low timing of about 32 degrees (I'll add more later)
Edelbrock Super Victor EFI Intake manifold
Edelbrock 1000 cfm Throttle Body
39# injectors
eMS-Pro running the fuel injection (megasquirt 1 extra)
904 trans with 3500 RPM converter.
Unknown compression
Unknown cam
4.10 gear
3450 lbs with me in it on the scale
Here is the best run from the night (left lane)
Any opinions?
39# injectors
Unknown compression
Unknown cam
4.10 gear
Any opinions?
