Ok folks I just did the brake conversion on my car here is the outcome.
Started with, 1964 Plymouth Barracuda, all stock 9 inch drums single master.
Ordered from RAMMAN Early A Body kit. 76 Dodge Dart Sliding Caliper.
Removed as a complete unit the drum assembly, remain upper and lower control arms.
Installed 62-76 steering spindles, RAMMAN gives you upper control are insert sleeve.
caliper holders, caliper pads. Right Stuff banjo brake hoses.
To keep stock rims 14 inch 5 1/2wide, need to either grind on caliper or wheel shim.
All fits well car looks stock again with modern braking.
