Timing covers?
WRB426
Insane 4 Mopars
MA
What are the differences on small block timing covers?
I need one for a 360. Not sure if any one will work and what part # I should look for.
I'll be running the Edelbrock water pump and 67 and up alt bracket.
Negating late LA EFI or Magnum, "about 70?" Ma went to the longer aluminum pmp with the timing marks on driver side, lower hose on pass side
Previous, the older short pump had the timing marks and lower hose reversed from above.
Ok thanks. I'll look for a driver's side timing mark one.
