ProStocker273
MoPar N Jeep
mguner that's a good looking dart. What are your back wheels?
Are you stretching to the front?......rear?......or both? for the 30" diameter tire
I wanted to stretch the front but I was hoping not to have to get into the rocker. If I stretched it forward I have 1-1/2" before I'd have to get into a rocker. And rearward I have about two inches to stretch before getting into the lower quarter trunk extension. I know a lot of guys push the axle back 1-1/2 to center tire to fit a 30".diameter tire. I'm going to push the axle back a 1" and if I have to stretch I may just split it front and back.
Just curious on these cars, what width tire (in inches") fits when leaving the factory inner well on the outside
I wish I would have left an inch on the outside edge on mine. Instead, I cut it flush so I didn't even have the option of doing a lap weld joint.
Good work so far. Looks like you will have caught me in no time.
