Ok, another tire size tutorial needed here? Tire sizes are read as follows, using your size as an example!
235= the width of the tread in millimeters, or 235mm
60= the height of the sidewall in relation to the tread width, or 60 percent of 235mm (141mm)
15= the diameter of the rim, or 15"
So, will it fit? I can't say, although it is a very large tire for the front of an early A! Geof
