Stripped out fuel pump mounting hole
hey, no problem buddy, i have a couple laying around here, just thought i would offer............hope to see you at bandimere next week!
higgs
Just bungee cord the loose side of the pump down, make sure to use a really expensive high temp bungeee cord, pull the loose end as hard as you can across to the far side of the timing cover, and put a hole tab under one of the bolts, permanent fix, I assure you.
Silly mode off:
Heli coils are magic; use them.
Yep, worked perfectly. Far side with the nice clean threads is the helicoil
