paulmi
Active Member
rpm air gap for carbed 5.9 magnum $300 canadien funds , used comp cam roller for 5.9 custom grind big cam 236/245@-0.50 and 571/576 lift on a 110 lobe separation very lumpy and needs compression and gears ..$250. Canadien $$$ power vacuum pump for big cam and power brakes $40
