D-mailman
Who makes good roller lifters ? What are you using in your engines. Will be street / strip use.
Thanks
D-mailman
Thanks
D-mailman
MRL Performance He makes the best IMO.Who makes good roller lifters ? What are you using in your engines. Will be street / strip use.
Thanks
D-mailman
Buy the highest quality roller lifters you can find. Expect to spend over $1k on solid rollers, and then send them in to have them inspected annually. They should be fine on the street as long as you don't have too high of spring pressure.Who makes good roller lifters ? What are you using in your engines. Will be street / strip use.
Thanks
D-mailman
Hey Fish, will be a solid.Hyd. Or solid roller lifters?
Thanks
D-mailman
