needing help
jlburg
Cedar Rapids, Iowa
Lets start with the basics. I have a 68 barracuda, 440 4spd. It has an 83/4 rear end and dart disc brakes up front ( I was told when I bought it) with the bigger torsion bars and sway bar.
Now on to the question. It seems when I push in the clutch, to shift gears. I have some wiggle, I'd call it. The harder the acceleration the more the wiggle. Any suggestions or ideas what would cause it, and or fix it. Thanks.
Jon
Check all the leaf spring mounting points and eye bushings. Also look at the u bolts to make sure they are tight first.
................. Also look at the u bolts to make sure they are tight first.
Might want to check for a torque spec on them.
While your at it check axle bearings and axle end play (up, down, in ,out). Give your tires a good look over too.
