[SOLD] 09 police hemi and trans
sport74
Anderson sc
09 5.7 police hemi with trans. Complet engine from intake to oil pan. Has throttle body, injectors, fuel rail, coils, water pump, idler pulley, and belt tensioner. Since it is an 09 model it should have MDS and I have read it has variable cam timing. The motor IS LOCKED DOWN! The trans is still good but not sure what happened to lock the motor down. The outside is free of signs that would indicate all the oil leaked out. I have the ecu and I am working on getting a harness. I also have the trans lines. I do not have the cosmetic cover that mounts on the intake. Asking 750 or best offer for all components.not interested in separating at this time. Located in Anderson SC, local pick-up preferred
Well.... That's true. I'm not in the pen.... But it is a police engine. Not real sure there is a difference, but it did come out of a cruiser.
That is a great deal. These babies are a relatively cheap rebuild and have massive component support for abody swap .
Here is pic of local car with 5.7 hemi, trans and ecu/harness install. She is badazz.
good luck with sale.
Thanks. If I didn't already have a 408 in the works, it wouldn't be offered for sale.
