I don't know much about this subject , so any advise is Great !
after a 20 mile drive yesterday I see a puddle under the trans - 1965 valiant 4 speed - Trying to determine where it was coming from I put it on stands , dried everything off , and ran it till it warmed up , then get back under and everything was dry except a small drip from the speedo cable , not at the trans , about 5 inches away. So is that a seal letting the fluid ride in the cable? or should there be some fluid in the cable , and the housing started to leak?
