1969 Barracuda Carb Suggestion Needed
What ^^^^^^ said. I used N-9Y Champions for many years, Also like Autolites and Now I use NGK.
That's a damn good TQ model you have. The flat machined portion on the top piece in the front indicates it's a mid 70s to 80s non emission version. The number is on the rear corner of the base plate. Should be like 6XXX or 9XXX
Oh really? The next time I head out I'll check the numbers and post them.
Hey all I have a built 360 in my barracuda with plans one day to upgrade back to a 383. The engine currently has a carter thermoquad on it and I would like something more performance oriented. I don't know much about carbs but I want my car to one day be a built daily driver, something that won't give me 5 mpg but at the same time if I give it some gas I want to go. The two question I have are one, if I get a carb for my 360 when I upgrade to a 383 can that carb transfer over. And two, what would someone with some more carb experience reccomend for a carb, that previously stated, does not give me horrible gas milage, but at the same time puts me in my seat. Thanks for all ideas and suggestions.
Without reading one more word of the thread the carb you have is the carb to have for this kind of build.
The numbers on the TQ will tell you what year it is and what it came on. You want the earlies year possible with the least amount of emmisions on it. Also you want the large primary model. They had produced an electric choke model but that has small primaries.
You can cut down Edelbrock AFB rods 3/4 of an inch and clip the extra off to fit the TQ if tuning parts are unavailable.
The TQ is they very best street and strip carb to perform. Period!
I didn't mean to lol. Everyone local has told me the one I have is just a junky stock one and to upgrade to something like a holley. Here's a picture of mine.
Uncap the bowl vent. Passenger side
Leave the small cap on the small port in the bowl. That is an EGR valve port.
On the base plate, the far left is the purge, leave capped
In the middle is the PVC port. Connect to PVC valve on the valve cover if you wish.
Far right is the vacuum advance port. Connect that to the vacuum advance on the distributor.
On the rear of the carb, there is on the passenger side a vacuum port for the dash pot. Connect it.
On the drivers side on the rear of the carb could be another vacuum port. This port may be capped.'it was used for a verity of things. 1 was to an air cleaners trap door.
Can you tell us anything about the engine build?
What rear gears and size tire are you running now?
What trans mission are you running and IF it is an auto, what stall?
First build at 19?
Have fun and good luck, we are here to try and help.
First build at 19?
Yep my first build, and I'm sure I've gotten myself into a deep project but its been fun so far, I don't regret anything... yet. I screen shotted the original Craigslist, thats about all I know about the engine, I could answer a few questions about it if you had any specific but thats how its built. It was originally an auto and one day I may put it back to an auto but for now its a 4 speed out of a different 69 barracuda. I have 14 inch mopar ralleyes on. I forget tire size but the backs are about an inch or two bigger than the front. Rear end it says in the add but its a 8 3/4 in a 4;10. Does this help?
Yea it does because tuning a carb is more than what is in the engine but the whole car is included on how the carb geate set up.
4spd & 4.10's?
Keep it that way!
I have that set up in my '73 Cuda.
Awwwwweee-soooooommmmme!
4spd & 4.10's?
Keep it that way!
The only kicker is I don't know how to drive stick lol. Here's pics of the numbers on the thermo quads, I have two. Cant tell if you can tell from the pics but it looks like the numbers on top started with a 9.
That engine build is nice for a 360 backed by a 4 speed. I love a TQ, but on this particular build I'd go with the 750 dp holley for this reason: With a 4 speed and 4.10's, first and second gear will bang fast, and the air flap on the secondary's be open/shut/open/shut in bang bang bang style. In this particular build, the mechanical secondary's, in my opinion, would be ideal for this build. Besides, if your new to cars, the TQ may be a little more challenging trying to tune.
Finally, somebody(318willrun) who understands TQs. I got laughed out of the house once for saying exactly, what you just said.
OP
I have had your exact combo, and it ran best with a 750DP. That cam is a little soft outta the gate, so 4.10s and the DP will really wake it up. And since that cam gas no chance at making any decent mpgs, you might as well shelf the TQ on this one.But don't sell the TQ, cuz you are gonna need it later when you pull that cam out. I mean in case you decide to pull out that cam. I mean that's a heck of a street cam! It loves to rev to make it's power.
But not every trip uptown involves reving to the moon.
I tell you what tho, don't be in a panic to swap it out. Your driving style might not be like mine.If you can wait until about 2400rpm (about 18 mph with your combo) before flooring it, it might be just fine for you. I just can't wait that long.I have places to go and things to do and I'm not getting any younger ya know. lol But if you do floor it before 2400, just try and keep it floored, heehee.
Is that 9013S? It is hard to read. Doesn't matter. It's a non emissions carburetor so it's a good one.
Okay, I'll look into the 750 double pumpers. Thanks.
OP
Alright ill look into the 750 double pumper. Since you've had my combo before do you remember how bad the gas milage is? I know its all about the smiles per gallon and all but I would just like to know for reference.
That's a 77 440 HP with AT truck carburetor. It's an 850. That's a dang good one.
FYI, all Carter carbs are mechanical in nature but lack the secondary pump shot nozzle of a Holley DP.
Like said, don't be in a hurry to swap it out.
Nobody that installs a 4.10 rear end is thinking much about mpgs. and after the 292 went in, mpgs became a distant,foggy memory,of something he thought he once knew something about.
292&4.10s pretty much means city-car/race-car, and these are like my cat with an open food-bag; she consumes for the joy of consumption.
I only kept that 292 for one summer, then I chalked it up to learning, and when a young unmarried man I had taken for a ride heard it was for sale, I let him have it,Pow. And one day maybe two summers later,when I asked him about it, he was still loving it.
I never took that combo on a road trip, so have no idea of it's potential to make mileage, but as a city-car it could burn a tankful in an evening, so Ima guessing it mighta made 120 to140miles in 4 to 6 hours. I'd call that right around 8mpgs with the Holley. I didn't run it very long with the TQ, and I love TQs!
AJ's Quest for the Funnest Street 360-4spd Combo;short version
Nobody that installs a 4.10 rear end is thinking much about mpgs. and after the 292 went in, mpgs became a distant,foggy memory of somrthing he thought he once knew something about
Oh alright. Thanks. I don't have any rush to get it swapped, I'm just wanting to get her running.
Which 750 would you recommend? I don't know much about carbs and even when I search just Holley 750 double pumper a huge list of them show up.
I read your article, it was very well written. I don't know much about carbs but which 750 double pumper would you recommend, I looked them up and a bunch come up. Also in your article you wrote that you were considering a turbo; is that something you think I could put on my current engine without blowing it up? I know you have to have a strong engine so it doesn't blow up with a turbo but I am unsure if mine is good enough.
this style....
[FOR SALE] - 750 Holley
Let me explain a couple of things, means you say you have really no knowledge on cars.
1). Picture yourself on a 10 speed bike. Your 4.10's are like having the 10 speed in 3rd gear. In other words, to travel with other bikers on a bike path, your legs are going to be rotating really fast, while their in 6th gear and barely moving their legs compared to you. Now, if you all stopped and lined up to race, your 3rd gear will help you beat them on the start, but if racing a longer distance, they'd soon be around you. So, you have to decide what your purpose for the car is going to be. If it's going to be mostly drag racing (1/4 mile), you'll like the gears. If your going to do a lot of daily driving (some on the highway), you might want to go to 3.55's behind that 4-speed. 2.76 gears would be like 9th gear on the 10 speed bike; 4.88 gears would be like 1st gear.
2). Your intake (M1 single plane) is designed for rpm's above 3500 rpm's. a Dual Plane intake will give more low end torque, more mpg. Most dual plane intakes will make more power than your single plane under 4000 rpm's, and make a better city driver. A lot of test have been done on small blocks, and there is very little gain at high rpm's on a single plane vs. dual plane, even at 6000 rpm's.
3). If I was you, I'd purpose the car. If it's a ground and pound, slam'n gear car, leave the gears and intake. If your going to do a lot of cruising with it, I'd go to 3.55's behind the 4 speed and go to a dual plane intake. This will up the mpg, allow more comfortable 60 mph cruises, and with a 360 still pound (may actually take more advantage of the torque). If you go to 3.55's, and a spread bore dual plane intake (even a factory cast), then that TQ would be hard for me to give up......
I personally had a dart once with a 360 in it. I went from 4.30's to 3.91's, and the E.T. stayed exactly the same.
this style....
Thanks for explaning, that did help a lot. I want something I can drive around but at the same time I want it to have really quick acceleration, or something I could do a 1/4 mile in. It sounds like for what I would want maybe keep the 4:10 but possibly get a new intake.
I think if you get it so it's running pretty good, you'll know more. Once you drive it, you'll know if it's what you want or not. Can't tell off of "paper", so to speak. You may take it down the road and say "am I stuck in second gear??? Why is it winding so bad?" .... then you'll know the 4.10's aren't for you. Or, you may do nothing else but shift gears and kick rears and say "i'm not changing a thang"..... LOL
