1975 318 Y pipe vs 1974 318 Y pipe
68 CUDA FORMULA S
Clarkston Michigan
I thought I read on here that the 1975 and up Y pipe for the catalytic converter has a bigger passenger side flange that bolts up to the exhaust manifold vs the 1974 and down Y pipe without the converter. If anyone knows for sure please let me know. This Y pipe that I bought had the set up for a converter and that might explain why I have a small exhaust leak coming from the passenger side flange.
Thanks
Bob
I just removed. 1975 Dodge Dart y pipe with a cat. The passenger side manifold was in fact larger diameter than the drivers side. The exhaust manifold was the same passenger side on the 360.
Good luck
Joe
Sorry the car was a 318 but the passenger side manifold that was factory was a 360.
Thanks Joe. I thought I remembered reading on here that the 75 and up Y pipe had a larger passenger side flange and that explains my small exhaust leak. Now I will look for a 75 and up passenger side exhaust manifold and see if that cures the problem.
Thanks again
Bob
