which 14" steel wheel for 73-76 disk brakes?
1963dartgt
Kansas
hey all looking to upgrade to disk brakes on the front of my dart and decided to go with factory setup from 73-76 a body.The problem a whole new set of rims and tires are out of the question so i was wondering which 14" rims will allow me to do the conversion that i can grab from a junkyard or off craigslist.
Yes, as abodyjoe said :thumbsup: I put the 73 76 front disc on my 66 and I grabbed up a pair of big bolt pattern stock wheels and put these on to role my car around as I do my 360 install and they work as they should
New yorker
5th ave
dippy
dodge truck some
all have big bolt pattern rims
I have a full set of BBP 14's if needed.
They came off my 73 Dart with discs when I swapped to 15's
The problem in california is there's not much in a junkyard that's older than the early 90's .
Up until a couple years ago I would have disagreed, but yeah, in the last couple of years the supply of pre-90's cars has really dried up. Just a two or three years ago I was still pulling parts off of 70's mopars in the yards pretty regularly.
Where in California are you? I have the 14" BBP steelies that came off my '74 Duster, plus a few extra. I'm near Sacramento.
Unfortunately I'm down in the LA area so a pretty far drive from here
I have a set of 14" factory Rally wheels off my 73 Dart with front disk for sale.
Located NC 28027
Scott
