[SOLD] 4.10 posi chunk for 8-3/4 rear
GotDart
Austin, TX
Purchased this here on FABO 12 years ago from Barracuda340s. I never installed it. Passing it on to someone who can get some use out of it. Here is what Brett said about it.
http://www.forabodiesonly.com/mopar/threads/gotdart-heres-your-4-10-locker.1143/#post-8973
GOTDART Here's your 4.10. The yoke is on it! That's the moser 1350 billet. You can see how much use it has had, the writing is still on the gears. This case is from Chrysler and is very rare. It was made for Don White who used to race nascar with Richard Petty and Ernie Derr. If you remember a couple years back in MM they did an issue about the first winged car to ever do over 200mph found behind a shed and they werwe gonna buy it back and restore it. It has a different body on it but it was the car. That is Don White! The rear's do not have casting number's on them, only the gear stamped on the snout which you can see in the pic. Do not ever sell this casing cheap! you will never see another one!
What else can I say? Oh yeah, did you notice the Detroit Locker? :)
$700 local pickup in Austin, TX. Will ship for another $90.
It has a Moser 1350 billet yoke.
1350 U-Joint Series 1.188 cap and 3.622 width. (1 3/16 x 3 5/8)
Per request, adding more pictures to better show wear pattern.
These gears were professionally set up for street/strip use. Wear pattern just doesn't get much better than that.
If you think my $700 asking price is out of line, consider that a Detroit Locker for 8-3/4 rear sells for $570 by itself. The Moser 3510 billet yoke goes for $100. Add a one-off 489 based NASCAR housing, a set 4.10 gears, bearings, shims, etc. plus setup labor. You cannot build a third member of this quality anywhere near what I am asking. And this chunk weighs a hefty 75lbs. I'm only charging $90 to ship, I can almost guarantee it will cost me more than that to ship.
My price is firm. I am not open to offers. $700 local pickup. Shipping in the lower 48 is $90 extra.
Drive
Coast
