ir3333
..do the the Voodoo line of cams produce any valve train noise?
Thats odd i know of 2 mopar cars with those cams and no noise.There not useing adjustable rockers,maybe thats the problim with noise,you dont get the lash right then theres your noise.hmm...so they are noisy like the Extreme energy cams from comp?
also run 701 cast rockers its quiet!i know its mild but the 701 in wifes 340 is quiet, oem valvetrain from 1972
...really...?(Smile.....).What's so bad about a little valve train noise. My 273 is a bit noisy and quiet when warm but if I run the valves a bit looser it clatters a bit and sounds good.
Valve train noise and engine ping are two different things. I have cruised into a Mopar show and had people follow me asking about my 273. I do the same with early Mustangs with HP289's...really...?(Smile.....).
Ran the 403 in my 416 when I first built it..ran the 404 in the same engine..ran the 405 in both the 416 and my 360..NO noise to speak of!!!
What heads and rocker arms did you use in your setup?
Question for the experts. Looking at the Lunati 60404 or 60405. My current engine rebuild is already headed in a totally different direction than originally intended due to the crank and 1 rod being bad. Anyhow, will this cam work with a stock based head with stock length valves? 60404 has .513"/.533" lift, 60405 has .533"/.552" lift.
What heads and rockers are you using?I have got one the 405 its quite in my 418 stroker
'Voodoo line' of cams covers a lot grinds, so maybe specify solid,hyd, etc . I can tell you a voodoo hyd roller w/ .585 lift is pretty quiet, and a voodoo solid that's no more or as noisy than a solid purple shaft...which is a tickity little sucker...do the the Voodoo line of cams produce any valve train noise?
