Apparently no one makes rear window seal/ gasket for 64 Dart
MitchDart
1964 Dart 270 Owner
Bay Area
Hi All-
I need a rear window gasket for a 64 Dart 2 door sedan (b pillar post).
I have looked all over and no one makes one.
The front is available, and other years for the rear window but not '64.
Has anyone had this same issue and found a solution?
Try looking for the seal for a 4 door. The 2dr sedans and 4drs use the same front and back glass,gasket and also the wing window assy's
Our vendor DMT here lists the windshield gasket as the same for sedan and HT
Unless your old one is torn or cracked, it can probably be salvaged. Lots of rags, a flat blade screwdriver, a can of lacquer thinner and a few hours of dirty, smelly wiping and scraping can make old parts flexible and looking almost new.
Give us a call.....we have 4 of them in stock on the shelf here in our warehouse ready to ship.
Thanks! Ill try to order this weekend and post the outcome.
Small bit of constructive advice to Laysons people: very hard to use and understand website.
Ordered and received. Appears to be the correct part (just visually). Taking it to the auto glass shop this week. Will post the 'after' pics.
