junior636
72 440 block, all machine work done by muscle motors in Lansing, Eagle Steel crank, Eagle h beam rods, diamond pistons, 493 stroker, indy ez440 heads with cnc ported intake side, exhuast side hand ported (gasket matched), stainless valves, comp solid roller lifters/1.5 rockers, lunati voodoo cam, .711 lift on exhuast and intake, copper head gaskets, comp timing chain set, edelbrock Victor Sr 4500 intake, fabricated valve covers, milidon dual line swivel pick up remote oiling system still in the box, msd crank trigger new in the box, brand new pro systems 1100 dominator carb that was just built to spec for this motor, have an electric water pump set up as well. Motor is 11.3:1 and should be 750-800hp on 93 pump gas. The only used part in the list above is the water pump set up, everything else is brand new, no used parts here. Needs pushrods, distributor and balancer. I have a main girdle plate but you would need to make up spacers, Ears for motor mounts are gone on driver side, would need to use a motor plate. Over $10k to duplicate, $8500 obo PM me for any serious offers or questions. Located in Grand Rapids MI
