Door and window weatherstripping for '62 4 door Lancer Wagon
pinkiedog64
Kerrville, TX
Hello all,
I want to replace the worn weatherstripping on my '62 Lancer wagon. Looking for where to buy the following:
window channel, front and rear doors
window "cat whiskers" or window sweepers, front and rear doors, inner and outer (set)
front vent wing window seal
front windshield seal with lockstrip
rear side glass seal with lockstrip
roll-up rear windshield channel/seal
Does anyone know a single source to get all of this from? Restoration Specialties looks to have the window channels and cat whiskers, but haven't found much on the rest.
Thanks!
Stephan
Stephan,
There is not a lots that is going to be available for the car. The windshield gasket, door seals (which color), window felts are available. The vent window seals, quarter glass and rear roll up window glass are not available to my knowledge. I will send you a private message as well.
Thanks,
Richard
None of these will be difficult. See here.
Not available. If you have a good one, you might send it to Gary Goers for repro.
Not available as a one-piece item; Gary Goers has material you can cut and mitre. Lockstrip you can get from Rare Spares in Australia, but you'll have to ask them for extra-long length on it; the linked item is the much shorter length needed for the sedans.
Probably also Goers, match up by profile.
