El Cheapo vs. 440
Ether the slip tube method or cut the fender. Hell of a job!
Looks like you're gonna have to come up north Michel to line up. Svensson told me he wont drive it himself when it's ready because he is $hit scared of it already. LOL.
Nice build man! Love work and graphics you put on the body! I would love to do a build like this..
I agree - do not reweld the headers, use but or lap joint clamps, with some sealing paste, that way you can remove with out metal or sparks going everywhere.. Keep it up!
Svensson told me that i have to drive it the Quarter for the first time.
But honestly i don´t really want to take his honor!:glasses7:
Lets see what happend in the future.:burnout:
Very cool project! Are those aircraft seatbelts you are using?
it seems that he´s doing some solid work....so i see no problem racing this thing. Even my POS did not loose a single part during some racing this year :D
Michael
Hehe :D This is right. I cannot install the headers, once they are welded together. I will install them and then weld them together. This way I can be sure to have no exhaust leaks.
The belts are 4pt Nascar from Beltenick. They were very cheap!
Michel, I really try to get the car running for the 2016 season. I really try hard!
In July we were on a trip cross the US on Route 66. This was great!
We had the Ram shipped and it will be El Cheapo's hauler.
So after that little break I could finish the Sedan-conversion
and finish the 6 pt rollbar. It should be welded onto the car's frame but I couldn't burn the fresh paint. This has to be done later ....
Making rear windows from Lexan
The material for the doors is on its way.
Finally I installed the seats and seatbelts again. Interior-work is nearly done!
Next will be the rear axle with little bigger wheels :finga:
This is a truly awesome build! Roadkill with proper paint!
A little worried about the non-headrest seats, though.
Man this is killer! Gonna be a wild engine bay ! I love it! Keep us posted!:burnout:
One year later I can show just a little progress...
My junkyard rescue from Fresno CA took some of my time. But I love these cars since I was a little boy...
It still doesn't run. But I had to go for now.
Hey! I didn't paint it. Just cleaned it carefully up. Was fun!
Ok. I emptied the doors of the Dart and copied the belt window regulators of the Hemi Dart.
To get the huge Pie Crust Slicks in, I had to install a Leaf Spring Relocation Set.
But I re-used all of the old hanger-parts, because they are from a way thicker material. I just boxed them with the parts of the set.
Chassis
8-3/4
Leaf Springs with a simple rebuild kit.
and installed
Lettering this time not with a sharpie but with correct enamel paint. This was fun!
now standing on the new rear wheels!
Front axle
Engine & Trans installed for a last trial fit.
This is the new stance. Far away from gasser style, but not too embarrassingly low in the front.
Next I will try to fit the vintage Mr. Gasket shifter into tunnel and hump.
See you!
Finally I realized that I would have to cut the car to mount my headers. There was way too less room to install the engine and then weld the headers together. These were the first cuts into the car that really hurt...
A4eOe4C89HzTK-oZ-OSJYZWO7FPYA3wq72PXiuEqTr9De4OtMmq1YwEruTPZjPjw1Lp_3neXmZ_J0iQX0YA=w873-h654-no.jpg
But now I was able to finish the headers. After mocup I will reinforce this area.
lWxNv1JI715MiT6aCyMkFN4T7slGwjkbaxnzaTSo4E-GT7twmz41LeAMeJDOGTq9b-9KIWjqJWnBTGst91Q=w873-h654-no.jpg
FceLoMMCbEbxTbSyRIgD3lW2QnkvCT_ZSmpvTdcrSOkcFqh5-ysNpRnNyWVio5q3920tFUJRQKo5Zi7G8Zg=w873-h654-no.jpg
Next thing was the nice Mr. Gasket Vertigate Shifter.
After cutting in the enginebay I was used to cut deeper than I wanted...
gHrcJJt0bHUHQiOoU_fKH-IooXcS8OAeEGNJp09Wpe26-kMyKBZo9-rIgt2Ckitt6y9Rt0F2abec15yGRxw=w873-h654-no.jpg
Building aircleaner from scrap
IGP7sS6ciFdNF6EZVsbmECmnYg6CJWcE7yyZT5iSXnHhptnNLVztQwOCiQuT4Aah1T4Y_jVwXT-xgy1rGUw=w873-h654-no.jpg
OGwyYshx3CVFtqM9_R2Rrxc4IEtpOo-uDwvl4taaX2xjndplTSNXJUkugGqA3wE12rzhR8FUUvJDWbHB57A=w873-h654-no.jpg
TqFEC0FhwuNHDh5SvGI1jQQUUa0uoJW9q09vCMNNlf9NC6oj6bIunRQrp5dk1Vk5HDmuWj8G-eyfxrRpJ7w=w873-h654-no.jpg
BlMBU5y0_9nWLqzwihrXLrEtA0b2AU7qOm4nB8eiQGk6UcClFba0PMBJiJchBjNE0gCZ2656fn2Xs22HT_A=w873-h654-no.jpg
my open air shop
57uyHp1j32pZmORCAArwpW-Xm9sxQ2_kcyUlFXXbatPvUsQfnyg7WLt-kCCfNGL7eem93aPW-6yr3ABf03w=w873-h654-no.jpg
now testfittig of the front.
To fit the aircleaner under the scoop and to get heat out of the enginebay, I raised the hood about 2" in the rear
78StqOh1FYELqXSrbMpKQVZjiPFxLjUDZW8LWb_1YDAl2aACHVifNOA6aU7ponQrwFo8rCUUrzbHfycez9g=w873-h654-no.jpg
Now it looks as ugly as before :realcrazy:
oZ1zq4J4rnCuX2ZnIt0kFWKG96ZbgmvRQXW_D27qjQ9adSTWP3zgOfY6uA9UsrroIzeXHQ7z3Jnp34l-NZw=w873-h654-no.jpg
Same time I reduced some more weight.
I deleted the handbrake. No one needs a handbrake!
And installed the instrument cluster without anything but the plastik top.
1ZGXvEuHuDsBrN5T_sgjlrPBmGH9KSKSZaHlVbA9l7vNp-uA_6rigMHnVHM5iXLSUtQILsuFgKEQMDhYV0w=w873-h654-no.jpg
Next thing is ripping it all apart and rebuilding the groups for final installation.
Need to go racing in May.
Really a nice job keep it up. Never even thought about running my headers like that
